Islamabad Airport Taxiways Maintenance Work
From February 8 to 28
Portion of Taxiway N abeam aircraft parking stand numbers 4 to 7 including aircraft parking stand numbers 4 to 7 not available due to maintenance at Islamabad International Airport. Pilots advised to exercise caution.
Notice to Airmen (NOTAM) issued:
Location of Islamabad International Airport Taxiway N and aircraft parking bay numbers 4, 5, 6 & 7 can be seen in this image:
faisal-777
Re: Islamabad Airport Taxiways Maintenance Work
Post by faisal-777 »
if the plane sizes shown in graphics are representative of the aircraft size that can dock on those bridges, it means for widebodies it could be a problem if there are more than 5 present at the same time? I usually have always seen this 4-7 gates used by QR, EK, TK, BA etc.
Averagespotter
Post by Averagespotter »
faisal-777 wrote: Sat Feb 08, 2025 7:24 pm if the plane sizes shown in graphics are representative of the aircraft size that can dock on those bridges, it means for widebodies it could be a problem if there are more than 5 present at the same time? I usually have always seen this 4-7 gates used by QR, EK, TK, BA etc.
I decided to count on google maps (peak autism). On the international terminal:
Triple jetways (presumably for a380s):
6 and 7
Double jetways (presumably for b777s, though a380 could potentially be operated as well):
4, 5, 9, 17, 18 and 19
Assuming that the largest aircraft in operation at the station is the b777, Islamabad's jet bridges could easily accommodate 8 wide bodies at a time (though immigration, check-in and baggage claim would be insanely crowded).
Previously, Islamabad International Airport offered six jet bridges for narrow-body aircraft and nine jet bridges for wide-body aircraft. Now eight of nine jet bridges for wide-body aircraft are also available for narrow-body aircraft.
faisal-777
Averagespotter wrote: Sun Feb 09, 2025 3:02 am
6 and 7
So with 4-7 not available for some time, widebodies only have below available (based your assessment of which ones can handle widebodies)
9 17 18 19 (only four).
I think there could be a timeslot where a widebody may need to park at remote bay and use bus boarding. Although i also cannot recall except midnight between 1:00 - 4:00 when do we have so many widebodies at same time at ISB.
Etihad usually operates A320/A321 for morning departure. EK / QR are present at same time while TK arrives when former two have departed (as well as BA comes later).
Only if theres a delay with QR/EK, could be a problem.
Some of Islamabad Airport terminal building boarding bridges used by wide-body aircraft flights after February 8.
Aircraft parking bay number 19 by Saudia Boeing 777 flight on February 11.
Aircraft parking bay number 18 by Emirates Boeing 777 flight on February 12.
Aircraft parking bay number 17 by Qatar Airways Boeing 777 flight on February 12.
Aircraft parking bay number 9 by British Airways Boeing 777 flight on February 10.
From February 22 to March 17
Portion of Taxiway N abeam aircraft parking stand numbers 7 to 10 including aircraft parking stand numbers 7 to 10 not available due to maintenance at Islamabad International Airport. Pilots advised to exercise caution.
Location of Islamabad International Airport Taxiway N and aircraft parking bay numbers 7, 8, 9 & 10 can be seen in this image:
From March 14 to April 6
Portion of Taxiway N abeam aircraft parking stand numbers 10 to 12 including aircraft parking stand numbers 10 to 12 not available due to maintenance at Islamabad International Airport. Pilots advised to exercise caution.
Location of Islamabad International Airport Taxiway N and aircraft parking bay numbers 10, 11 & 12 can be seen in this image:
From March 17 to 27
Portion of Taxiway K between Taxiway F and Taxiway T not available due to maintenance work. Runway 10L/28R will be used for aircraft taxiing during this time period.
Location of Islamabad International Airport Taxiway K between N and Taxiway F and Taxiway T can be seen in this image:
Islamabad International Airport runways:
Primary Runway 10R/28L
Secondary Runway 10L/28R
