ATR Engine failure on Ist flight
FMC
Deactivated
Post by FMC »
The newest ATR to join the PIA fleet had an engine failure on it's maiden flight to Gawader on 20th May. Prior to that the aircraft engineers' posted 182 objections on the acceptance sheet. The plane however was flown to pakistan by some other signatory.
Is it AP-BHO?
AN
Post by AN »
where did this info come from? it is completely false.
the newest ATR to join PIA is based in pindi, and there are no flights from pindi to gwadar.
PK777
Post by PK777 »
Well if its true.. these things happen because they are new aircraft. Once these small problems get sorted out.. they will run smoothly..
Post by Amaad Lone »
F.M.C
A.N
Well F.M.C waiting for your reply, AN has said that your information is not true. Do you have something to reply???
