Does anyone know what's keeping PK713 KHI-IAH on the ground in KHI so long this morning? It was sceduled to leave KHI at 0245 but the Call Center say it won't leave till about 9:40 a.m.
I'm worried because the good Mrs. Salampaks and Jr. Salampaks' No's 1,2 and 3 are at KHI and strangely out of contact.
Any info will be appreciated.
What's up with PK713 today (wednesday Jan 4th)?
pia is face problem due top fog at isb, lhe and man airports due to that most of aircarft are running 5-10 hours behind the flight time, right now only 3 777 operating to noth america destination and since week end they are running late , that why aircarft comining from yyz will operate later.
best regrds
best regrds
Muhammad Ali - London - UK
Always Pakistan First, Pakistan Zindabad
Thanks Muhammad Ali.
BTW, I called the contact centre twice and two different agents used the term "stuck-up" to describe why the aircraft was late. The first said "jahaz estuck up hogaya tha". Fair enough, maybe I can get a better explanation from someone else. "Sir, the plane is stuck up due to bad weather" was the second agent's response when I tried back an hour later. Is "stuck up" valid PIA vernacular to describe an aircraft that is delayed?
