Multan-bound PIA Airbus A320 Flight PK222 Aborts Takeoff from Dubai Airport
According to news sources:
On September 30, PIA Airbus A320 (aircraft registration AP-BLY) flight PK222 to Multan rejected takeoff from Dubai Airport Runway 12R around 12:29 PM (local time) around the speed of 80 knots. A number of aircraft tires deflated due to rejected takeoff. The aircraft was carrying 172 passengers.
The takeoff was rejected due to a warning/indication related to engine received in the cockpit. PIA Airbus A320 aircraft registration AP-BLY is powered by two CFM56 engines.
The aircraft is still on the ground at Dubai Airport. PIA flight PK222 from Dubai is appearing as cancelled on Multan Airport website.
Source: multaninternationalairport.com.pk
On September 30, PIA flight PK222 was scheduled to leave Dubai at 11:40 AM and arrive in Multan at 3:30 PM.
September 30, PIA Dubai to Multan flight PK222 status appearing as "Non Operational" on Dubai Airports website.
Source: dubaiairports.ae
Re: Multan-bound PIA Airbus A320 Flight PK222 Aborts Takeoff from Dubai Airport
PIA to adjust flight PK222 passengers on airline's other flights from UAE to Pakistan including:
October 1 Dubai to Lahore flight PK204.
October 1 Sharjah to Multan flight PK294.
PIA Engineering team from Karachi to arrive in Dubai on October 1 to inspect and repair airline's Airbus A320 aircraft registration AP-BLY grounded at Dubai Airport.
Brief Report
Operator: Pakistan International Airlines (PIA)
Aircraft Type: Airbus A320
Aircraft Registration: AP-BLY
Flight Number: PK222
Route: Dubai (DXB) to Multan (MUX)
Occurrence Date: September 30, 2024
Occurrence:
Aborted takeoff due to engine number 2 (right side engine) Exhaust Gas Temperature (EGT) exceedance (EGT reached 960°C).
During post-abort inspection tire numbers 2 and 3 were found deflated with temperatures recorded at 800°C.
Troubleshooting/Rectification:
Initial visual inspection of engine intake and exhaust revealed no external damage.
Inspection and investigation in progress.
Aircraft on Ground (AOG) at Dubai Airport (DXB).
Borescope Inspection (BSI) team and 4 spare tires/wheels dispatched on PIA Airbus A320 (AP-BOL) flight PK213 from Karachi that arrived in Dubai at 2:49 AM on October 1.
PIA Airbus A320 aircraft registration AP-BLY has completed 10 days on the ground since takeoff rejection from Dubai Airport on September 30.
https://www.flightradar24.com/data/aircraft/ap-bly
On October 17, PIA Airbus A320 aircraft registration AP-BLY returned to the skies when it left Dubai at 12:47 AM apparently as ferry flight PK6214 to Karachi. It was on the ground at Dubai Airport since September 30.
On October 17, PIA Airbus A320 aircraft registration AP-BLY apparently as ferry flight PK6214 departed from Dubai at 12:47 AM and arrived in Karachi at 3:29 AM. Dubai to Karachi flight completed in 1 hour 42 minutes.
AP-BLY was on the ground at Dubai Airport since September 30.
