Fly Jinnah (FJ) Airbus A320 Flight 9P670 to Islamabad Returns to Karachi for Technical Reason
On June 2, Fly Jinnah (FJ) Airbus A320 (aircraft registration AP-BOV) flight 9P670 to Islamabad returned to Karachi for technical reason. The aircraft was carrying more than 150 passengers including Governor Sindh Kamran Tessori and his family members.
The aircraft departed from Karachi Airport Runway 25L at 7:05 AM and landed safely on Karachi Airport Runway 25L at 7:55 AM i.e. 50 minutes after takeoff. Maximum altitude attained by the aircraft 23,250 feet.
The aircraft has been grounded and Karachi to Islamabad flight 9P670 cancelled.
Fly Jinnah (FJ) Karachi to Islamabad flight 9P670 appearing as cancelled on Karachi Airport website.
Source: karachiairport.com.pk
Karachi Airport runways:
Runway 07L/25R
Runway 07R/25L
Re: Fly Jinnah (FJ) Airbus A320 Flight 9P670 to Islamabad Returns to Karachi for Technical Reason
On May 24, the same Fly Jinnah (FJ) Airbus a320 (aircraft registration AP-BOV) as flight 9P843 to Karachi returned to Lahore for a technical reason
viewtopic.php?t=32579
Sami Warsi
Post by Sami Warsi »
BOV need a heavy maintenance
On June 2, Fly Jinnah (FJ) Airbus A320 (aircraft registration AP-BOV) arrived in Sharjah apparently as ferry flight 9P991 from Karachi.
Seems the aircraft is to undergo maintenance checks/inspection in Sharjah.
Sharjah-based Air Arabia is a joint venture partner in Fly Jinnah (FJ).
The aircraft left Karachi at 9:19 PM and arrived in Sharjah at 9:58 PM. Karachi to Sharjah flight completed in 1 hour & 39 minutes. Maximum altitude attained by the aircraft 38,000 feet.
arshad.altaf
Post by arshad.altaf »
Plane carrying Sindh Governor makes emergency landing
A private airline flight bound for Islamabad from Karachi made an emergency landing at Karachi airport on Sunday after experiencing a technical malfunction. Sindh Governor Kamran Tessori and his family were on board the flight and narrowly escaped the incident.
Sources revealed that the Fly Jinnah flight, carrying Governor Tessori and his family, encountered a technical issue shortly after takeoff. The pilot immediately requested emergency landing permission from air traffic control.
Flight number 670, carrying over 150 passengers including the Sindh Governor, had to make an emergency landing. This is not the first incident involving this particular Fly Jinnah aircraft, which has made several emergency landings in the past two weeks due to technical issues.
According to sources at the Civil Aviation Authority, the flight was canceled after the emergency landing. The aircraft, which had been airborne for 25 minutes, was in the airspace of Nawabshah when the technical malfunction occurred.
The Fly Jinnah pilot successfully navigated the aircraft back to Karachi airport. Air traffic control cleared the runway for landing.
It is noteworthy that this is not the first time Governor Kamran Tessori has experienced a technical malfunction on a flight, leading to an emergency landing.
https://english.aaj.tv/news/330363344/p ... cy-landing
June 6, Fly Jinnah (FJ) Airbus A320 (aircraft registration AP-BOV) arrived in Karachi at 9:24 AM as ferry flight 9P992 from Sharjah completed in 1 hour & 40 minutes.
Later, AP-BOV resumed performing Fly Jinnah (FJ) commercial flights when it left Karachi at 10:49 AM as flight 9P851 to Quetta.
https://www.flightradar24.com/data/aircraft/ap-bov
