Technical Problem Delays Departure of PIA Boeing 777 Peshawar to Jeddah Flight PK841
Aik News
Technical problem in the aircraft has delayed departure of PIA Boeing 777-300ER aircraft registration AP-BMS Peshawar to Jeddah flight PK841 by more than 8 hours. The flight was scheduled to leave Peshawar at 4:50 PM on May 27.
Delay in flight departure caused inconvenience to Hajj pilgrims.
May 27, PIA Peshawar to Jeddah flight PK841 status appearing as delayed on Peshawar Airport website
Source: peshawarairport.com.pk
Re: Technical Problem Delays Departure of PIA Boeing 777 Peshawar to Jeddah Flight PK841
PIA Boeing 777-300ER aircraft registration AP-BMS is apparently still on the ground at Peshawar Airport where it had arrived at 1:26 PM as flight PK842 from Jeddah on May 27.
https://www.flightradar24.com/data/aircraft/ap-bms
The aircraft unavailability has disrupted PIA flight operations.
On May 29, PIA Boeing 777-300ER aircraft registration AP-BMS returned to service when it left Peshawar at 1:48 AM as flight PK841 to Jeddah.
The aircraft had experienced technical issue with air conditioning system, according to news report on following link:
https://e.jang.com.pk/detail/693115
