Karachi-bound airblue Airbus A321neo Flight PA207 Returns to Islamabad After Experiencing Engine Problem
On October 30, airblue Airbus A321neo (aircraft registration AP-BOD) flight PA207 to Karachi returned safely to Islamabad after experiencing engine problem.
Details here: https://avherald.com/h?article=5106f9fe
Re: Karachi-bound airblue Airbus A321neo Flight PA207 Returns to Islamabad After Experiencing Engine Problem
On October 30, airblue Airbus A321neo (aircraft registration AP-BOD) as flight PA207 to Karachi departed from Islamabad Airport Runway 28L at 5:41 PM and landed safely on Islamabad Airport Runway 28L at 6:00 PM i.e. 19 minutes after takeoff. Maximum altitude gained by the aircraft 8,000 feet.
airblue Airbus A321neo (aircraft registration AP-BOD) is powered by two CFM International LEAP (Leading Edge Aviation Propulsion) engines.
airblue flight PA207 to Karachi was scheduled to leave Islamabad at 5:30 PM.
airblue Islamabad to Karachi flight PA207 status appearing as "Returned to Stand" on Islamabad Airport website:
Source: islamabadairport.com.pk
Islamabad International Airport runways:
Primary Runway 10R/28L
Secondary Runway 10L/28R
airblue Airbus A320neo aircraft registration AP-BOD engine number 1 failure has been rated as a serious incident by Pakistan's Safety Investigation Board (SIB).
Details on The Aviation Herald:
AP-BOD remains on the ground at Islamabad Airport since the incident day i.e. October 30, 2023.
https://www.flightradar24.com/data/aircraft/ap-bod
On November 14, airblue Airbus A321neo aircraft registration AP-BOD returned to the skies when it left Islamabad at 2:17 PM as ferry flight PA9001 to Karachi where it arrived at 4:41 PM. Islamabad to Karachi flight completed in 2 hours 24 minutes.
Apparently for some technical reason, the aircraft completed this ferry flight at lower altitude. Maximum altitude gained by the aircraft 16,000 feet.
airblue Airbus A321neo aircraft registration AP-BOD was on the ground at Islamabad Airport since October 30, 2023.
