Its quite interesting and it show much airlines take care of passengers unlike PIA
http://airnation.net/2012/07/02/air-fra ... oor-paris/
alimirfin wrote: Its quite interesting and it show much airlines take care of passengers unlike PIA![]()
I dont see any comparison between AF and PIA with reference of this incidence unless you can provide some examples:alimirfin wrote:Air France operates daily A380 flight from Paris to Tokyo, yesterday it was btw Finland and Sweden's airspace when they found some problem . They decided to get back to Paris and for that purpose they dropped 70,000 litres of fuel from air into Baltic sea so they could land back in Paris safely.
so you are not sure of the T7 flight with cracked cockpit wind screen...i think you need to be confirmed yourself first, search any such authentic source of information and then say some thing other wise dont just finger on PIA and in my opinion PIA has never put passengers lives on risk, whereever it needed like diversion, emergency landings etc, it did upto its best level and this is the reason why PIA pilots are one of the best in the world!haroon_ek wrote:I don't want to go against PIA, but if I am not wrong, there was an incident in which a B777 went from Lahore to Karachi with the cracked cockpit wind screen held by Gaffer tape or something like that. I might be wrong but I did hear such incident! Can anyone confirm????
raihans wrote:so you are not sure of the T7 flight with cracked cockpit wind screen...i think you need to be confirmed yourself first, search any such authentic source of information and then say some thing other wise dont just finger on PIA and in my opinion PIA has never put passengers lives on risk, whereever it needed like diversion, emergency landings etc, it did upto its best level and this is the reason why PIA pilots are one of the best in the world!haroon_ek wrote:I don't want to go against PIA, but if I am not wrong, there was an incident in which a B777 went from Lahore to Karachi with the cracked cockpit wind screen held by Gaffer tape or something like that. I might be wrong but I did hear such incident! Can anyone confirm????
It is good that you corrected your statement about T7 wind screen cracking news, i dont know about the B747 incident. Anyhow coming to A310 issue, i remember that French authorities impounted it due to having number of snags found which were not in compliance to safety but can you prove your statement about fixing the fule pipe fastened using steel wire?faisal-777 wrote:raihans wrote:so you are not sure of the T7 flight with cracked cockpit wind screen...i think you need to be confirmed yourself first, search any such authentic source of information and then say some thing other wise dont just finger on PIA and in my opinion PIA has never put passengers lives on risk, whereever it needed like diversion, emergency landings etc, it did upto its best level and this is the reason why PIA pilots are one of the best in the world!haroon_ek wrote:I don't want to go against PIA, but if I am not wrong, there was an incident in which a B777 went from Lahore to Karachi with the cracked cockpit wind screen held by Gaffer tape or something like that. I might be wrong but I did hear such incident! Can anyone confirm????
If I recall correctly, PIA did not actually use any tape rather the crack appeared after the B747 took off. The pilot landed back for repairs and then flight departed after some 4-6 hours of delay. Cant recall when exactly did this happen but is a recent incident. Nothing like use of tape etc.
However, the A310 that got "impounded" by French aviation authority in CDG was reported to have its fuel pipe fastened using steel wire, alongwith 30 other technical defects
raihans wrote:It is good that you corrected your statement about T7 wind screen cracking news, i dont know about the B747 incident. Anyhow coming to A310 issue, i remember that French authorities impounted it due to having number of snags found which were not in compliance to safety but can you prove your statement about fixing the fule pipe fastened using steel wire?faisal-777 wrote:raihans wrote: so you are not sure of the T7 flight with cracked cockpit wind screen...i think you need to be confirmed yourself first, search any such authentic source of information and then say some thing other wise dont just finger on PIA and in my opinion PIA has never put passengers lives on risk, whereever it needed like diversion, emergency landings etc, it did upto its best level and this is the reason why PIA pilots are one of the best in the world!
BTW, its not a fault on the flight crew instead we can say it is negligibility of PIA engineering if your statement is true!
Thank you for withdrawing your statement, i really appreciate thatfaisal-777 wrote:OK I tried to get hold of such document but no one seems to have it. Perhaps it was an misunderstanding regarding the document. The steel wire claim can be taken unconfirmed report. Heard it from someone so stays a weak information. Apologies
