Karachi Airport to Get New Passenger Boarding Bridges
Pakistan Civil Aviation Authority (CAA) tender notice in today's (February 24) newspaper for supply of a total of 12 passenger boarding bridges for Jinnah International Air Port (JIAP), Karachi, to replace the existing boarding bridges installed at the airport.
Is installation of these new boarding bridges related to making Karachi Airport ready for Airbus A380 operations?
AbdulAziz
Re: Karachi Airport to Get New Passenger Boarding Bridges
Post by AbdulAziz »
is it going to be like Dubai airport bridges?
A.Azizi
787
Post by 787 »
Could the old bridges be used again for smaller airports like FSD,PEW and UET?
SalamPaks
Post by SalamPaks »
Based on the tender notice, it doesn't look like this is to upgrade the existing bridges, so I'm curious to know if there are maintenance issues with the existing bridges or if 20 years is the lifespan of the things?
Zulfiqar
Post by Zulfiqar »
Salampaks,
if you read in the description column it says 9 bridges for ISB, 2 for MUX and 12 'replacment for existing installed PBB' for KHI.
malpensa26
Post by malpensa26 »
i hope the karachi ones are glass like dubai otherwise who could tell their new...lol
and new ISB was to have 15 gates? hopefully they use all 9 as international and not 5 intl and 4 domestic ..that would be a waste in my opinion
mhansari
Post by mhansari »
They probably won't be the glass ones because CAA earns significant revenue from the advertising installed inside and outside the bridges.
Tender cancellation notice appeared in April 27, 2012 newspaper.
But I think at least for the new terminal building of Multan Airport and new Islamabad Airport, CAA will issue a new tender notice for the procurement of boarding bridges.
According to an addendum published in today's (January 19) newspaper, aircraft stand equipment required for New Benazir Bhutto International Air Port under a pre-qualification notice published in December 25, 2012 newspapers and its corrigendum published in January 11/12, 2013 newspapers is now also required for Jinnah International Air Port (JIAP), Karachi.
So, the Aircraft Stand Equipment required for Karachi Airport is:
a) Passenger Boarding Bridges
b) Visual Docking Guidance System (VDGS)
c) 400 Hz aircraft Ground Power Units (GPU) with in-ground pits system
d) Pre-Conditioned Air (PCA) units with in-ground pits system
e) Integrated Aircraft Stand System (IASS)
Addendum published in today's (January 19) newspaper.
Pakistan CAA pre-qualification notice that was published in December 25, 2012 newspaper for New Benazir Bhutto International Air Port Project, Islamabad.
Corrigendum that was published in January 11, 2013 newspaper for Aircraft Stand Equipment.
mhansari wrote:They probably won't be the glass ones because CAA earns significant revenue from the advertising installed inside and outside the bridges.
Advertisments can be places on glass lined bridges too. plus there is always solid place for such posters.
malpensa26
so any updates on new bridges?
Ameerjan
Post by Ameerjan »
Good News... But as far i think they are only going to install new bridges in place of existing bridges and there will be no any changes.
If they are replacing the bridges so they should at-least create double bridges at one gate of International terminal which should be use for A380 Operations at jinnah Internation KHI or ISB.
Karachi Airport will soon be equipped with new passenger boarding bridges, according to statement of Director General Civil Aviation Authority (CAA) on a local news channel.
Post by 747-300 »
Hope Karachi airport is modernised to handle the a380 because emirates would be eager to operate a380 opertaions at khi as they serve it 6 a day :shock:
P.s i would be able to capture my first a380 ever
According to information in Pakistan Civil Aviation Authority (CAA) supplement in today's (March 9) newspapers:
Replacement of passenger boarding bridges (quantity 12) at Karachi Airport is in contract signing process.
