FS 9 Help
FS 9 Help
So my aircrafts REFUSE to turn on ground while taxiing and all. What should I do? :s I use my joystick and they used to tun and taxi fine but then all of a sudden something happened and now they dont. Please someone help as its very annoying to turn the aircraft using the tail rudder :/
Re: FS 9 HELP.
I think that your FS9 has some virus or is corrupted may be .... try re-installing it
Feathers shall raise men even as they do birds towards heaven : That is by letters written with their quills.
See you @ http://piasvirtual.org
Re: FS 9 HELP.
could you please elaborate more about the problem you are facing at the moment?
Normally, you require the taxi speed between 1 ~ 40 knots for turning, the speed vary considering the turning angles.
btw, i never knew about B777-300LR (your username), should be a B777-300ER or B777-200LR
Re: FS 9 HELP.
Hi "B777-300LR". As Raihan has mentioned that too much speed could be the reason as well as sone corrupt/ missing files in your FS directory could also be the reason. I would also recommended you to try different aircraft as some aircraft have this default issue with not turning the way you want them to turn.
If your other aircraft turn (default FS9 aircraft) then it must be the add-on aircraft problem and for that you can try downloading the same aircraft but by a different producer. I hope that would help.
Raihan maybe B777-300ER/200LR was already taken by someone else hehe lol
Which means we're travelling 97 times the speed of sound. And yet we can't feel the motion, SubhanAllah
Re: FS 9 HELP.
Thanks guyss.
Raihan : If i want to taxi from the gate to the runway, the aircraft doesnt turn it just keeps on moving in a straight path.. Ive tried the speeds and all, doesnt work still. Ive tried re installing FS9 too but to no avail.
And as for my username, I made this account somewhere in grade 7th, when I barely knew about A-Cs. Hence B777-300LR Lol
Re: FS 9 HELP.
YAY Problem solved
I turned on auto rudder now it works. thnaks anyway guys
Re: FS 9 Help
Same problem with my mighty jumbo PIA Boeing 747-367 AP-BFW
It's always better to be down on the ground wishing you were up in the air than up in the air wishing you were down on the ground.
Re: FS 9 Help
I have some other kind of problem hope u guys have the solution:-
when I add any airports to my FS2004 such as KHI , LHE, Hail , RUH my FS start getting hang and shut down ...
A.Aziz
A.Aziz
