Another Suggestion. You will notice that the Urdu PIA on all 777s is a more slender version of the heavier one seen on other PIA aircraft (like 747, A310 etc). The most glaring difference is when the dots are compared. Here's a sample:
The nose of the Hogan 777 has a slim chance of being tweaked as that would involve reshaping the mold which will cost thousands. This is one of the reasons I prefer the Skymarks/Risesoon 777 mold as its spot on. However Hogan is superior when it comes to their Airbus models and small details and the overall fit and finish of the model.
Can something be done about struts of all landing gears, they look very plain and crude!, bit on thicker side also. Some fine added detail and proper oleos and torx/suspension arms would make them look better.
very nice Moin bhai..........just had a question, how do you separate the gear from the plane? or is it 2 different options available, one with gear dn and one up? thanks in advance.
The model has the option of being displayed with the gears up (removed) or gears down. They are snap on gears and very easy to install. For the gear up configuration, closed gear doors are included so that the empty gear holes are not visible.
PIA won't commission these models for themselves as they're not in a position to order models right now, but I just want to get an 'ok' from PIA that Hogan can produce these models, with the result that PIA will get free models as royalty. There are already countless models being produced of PIA a/c of which PIA hasn't a clue about so this should not be a problem. The problem is me taking the time out to see the necessary person about it.
The original was another Urdu logo version used on early 747-200, A300, Dc10 and probably later on 90s livery A310.
Shame on PIA chairman, managing director, board of directors, staff, designers and all others related to the new livery, who have contributed to further ruination of this once prestigious airlines image.
