flying in fsx
bhattman
flying in fsx
Post by bhattman »
Any tips on how to keep the nose level whilst flying? Iam having real problem trying to maintain altitude and heading. The control just dont respond well? 8-[
Nadir Ali
Re: flying in fsx
Post by Nadir Ali »
If you want to fly the plane manually then use the trim to ease the pressure for you. If you dont use the trim, you'll be fighting the controls with little progress.
If you want to fly using auto-pilot, then just select the altitude & heading you want.
what type of plane are you reffering to? Single engine, or multi-engine trubo-props or jet liners?
bhattman
Re: flying in fsx
Post by bhattman »
Thanks Nadir bhai i will try that. Iam trying to fly 737-400, with real difficulty.
Nadir Ali
Re: flying in fsx
Post by Nadir Ali »
bhattman wrote:Thanks Nadir bhai i will try that. Iam trying to fly 737-400, with real difficulty.
If you look at the control panel, it's not so hard to fly. The place where it says alt is where you can select your alt and activiate the switch once done so.
hdg=heading.
alt=altitude.
spd=speed.
select all of these prior to take off and then press the switches. Once you have taken off the the master autopilot switch button located on the far left to activate the desired speed heading & altitude. If you can post a pic of the 737-400 cockpit, i can guide you through it, however dont try to fly manually or even taxi the plane unless you have a control yoke and rudder pedals for your flight simulator.
Just select the desired runway and the Flight sim will place you there directly.
Re: flying in fsx
Last evening, i was on command of virtual flight PK 206 Kuwait-Lahore, while flying over Iran with Tehran center i requested for FL350 rather than flying on assigned FL290 for better fuel consumption. As i reach FL350, did some "panga" on autopilot console and got the A310 out of control, stalled, rolling over and over and diving with more than 500 kts and finally got crashed :oops: tried to recover it from stall but to no avail :( and got so sad at this tragic loss of virtual PK 206 that i have had to shut down my FS and PC as well :evil:
zainmax
Re: flying in fsx
Post by zainmax »
How can I download and install addons in FSx.
Like PIA aircraft,sceneries,latest commercial aircrafts,etc.
Re: flying in fsx
zainmax, i am not flying in FsX so cannot help you :( might be someone else can whose using FsX :)
captain_salman
Re: flying in fsx
Post by captain_salman »
Hello Zain,
I use FSX, and I will help you know how to add the planes, and sceneries just PM me :)
See you at vpia.org
Virtual Pakistan International Airlines - The Wings of Pakistan!
