Never before seen photos of PIA's AP-BCP crash at Kathmandu
hammadh
Post by hammadh »
These are some never before seen photos of PIA's ill-fated AP-BCP's crash at Khtmandu.
Pakistan International Airlines Flight 268 was an Airbus A300B4-203, registration AP-BCP, which crashed on approach to Kathmandu's Tribhuvan International Airport on September 28, 1992.
A total of 167 people lost their lives in this tragedy, among them 155 passengers and 12 crew members. May Allah bless their souls. Ameen.
Hammad
Man learned to fly when he stopped imitating birds.
Very tragic incident in PIA's history.
PIA711HVY
Post by PIA711HVY »
well i'd like to tell u guyz there are lot of pics available with f/o faisal junjua who is the son of the captain of this ill fated flight.
very tragic indeed...thanks for sharing these pictures.
May Allah bless all those departed souls, (Ameen)
HASSAN JAVED
Post by HASSAN JAVED »
Was there any technical fault in this plane??????????
nopy99
Post by nopy99 »
Nasir
Post by Nasir »
I believe the shoe is the standard issue airhostess uniform...
Aer Pakistan
Post by Aer Pakistan »
i still remember's Crew face , when ever i see any picture of AP-BCP my heart cry :(
Muhammad Ali - London - UK
Always Pakistan First, Pakistan Zindabad
Nasir wrote:I believe the shoe is the standard issue airhostess uniform...
Similar thought came to my mind.
Following are some related photos/scans with information for members wanting to learn more about flight PK-268 tragedy.
Volume 3 of the book titled Air Disaster has a chapter on Thai and PIA accidents in Nepal. I have copied following info and scanned diagrams from this book for forum members.
A second Kathmandu tragedy
History has a painful tendency to repeat itself. But rarely does it do so as swiftly it did in Nepal, only 59 days after the loss of HS-TID (Thai Airbus A310-300), when the Sierra Approach to the Tribhuvan International Airport's Runway 02 claimed another Airbus victim.
The pitiful scatter of Thai wreckage had been abandoned by the investigators on August 19, but the Nepalese Investigation Commission was still hard at work piecing together the events that led to the disaster.
Even while HS-TID's CVR and FDR were still yielding their data to investigators in Ottawa, on September 28, 1992, AP-BCP, an A300B4 belonging to Pakistan International Airlines (PIA), was joining the Sierra VOR/DME 02 approach to Kathmandu. Operating as flight PK-268 from Karachi, this larger Airbus had a crew of 12 and carried 155 passengers.
The weather, even so late in the monsoon season, was similar to that of July 31, with a low overcast, drizzle, poor visibility and little or no wind. Descending in cloud on the 202° VOR radial at around 2.30pm local time that afternoon, the Airbus flew directly into the densely wooded southern side of the fan marker hill at an elevation of 7300ft (3000ft above the airport), only a few hundred feet below its summit. There were no survivors.
The much less forbidding and far more accessible crash site of the PIA Airbus only 9.16 DME short of the VOR on the Sierra approach track, enabled investigators to quickly determine that the A300 was established in its landing configuration, with slats, flaps and undercarriage fully extended, and that it was under power and on track.
In this instance the aircraft was an early model A300B4, with conventional control systems, traditional avionics and a three crew flight-deck, and the investigators could find no technical reasons that could have contributed to the accident.
There was no CVR record of flight-deck conversation, but the crew had not reported any problems.
But having acquired the correct final approach track, which it subsequently maintained, the aircraft had begun its descent in an altitude profile that was consistently "one step ahead" of the published DME descent profile.
As a result, the Airbus was more than 1000ft lower than the minimum altitude prescribed by the published DME steps for the Sierra approach when it struck the hillside. The A300's descent profile appears on the accompanying diagram, together with that of the Thai A310.
Scanned from Air Disaster - Volume 3 - (Abbas Ali Collection)
ATC recordings showed that at 16 DME the A300 crew misreported their height by 1000ft (the lower of the two aircraft's initial approach profiles shown in the diagram). A further transmission from the Airbus at 10 DME, the start of the Sierra Approach, advised they were at 8200ft where the required safe minimum was in fact 9500ft. Within seconds an alert tower controller challenged the Pakistani crew for an altitude check but it was already too late. That an error was made by the PIA crew seemed beyond dispute.
Final reports on both accidents were released within weeks of each other in June and July 1993, and the part played by the Kathmandu controllers was perhaps the best summarized in that on the PIA disaster: "Some air traffic controllers at Kathmandu had a low self-esteem and were reluctant to intervene in piloting matters such as terrain separation."
This was not only reinforcement of conclusions drawn from the Thai crash. Misreading poorly-designed approach charts was obviously also a factor in the loss of the A300, viz: "the pilots failed to follow the published approach procedure". And "the inevitable complexity of the [Sierra VOR/DME] approach and the associated approach chart" were "contributory causal factors".
The flight profile diagrams in this chapter include extracts from the two different charts used in the Kathmandu disasters, showing the benefits and limitations of two varying interpretations of the DME descent steps. They provide a comparison of the graphic styles and perhaps some understanding of how the PIA crew could misread a chart so fatally.
December 13, 1991's commercially available Jeppesen-Sanderson approach chart for Tribhuvan International Airport, Kathmandu, Nepal. Jeppesen-Sanderson approach chart exactly like this one was used by the crew of ill-fated PIA Airbus A300B4. The Nepalese Commission's report criticized Jeppesen-Sanderson approach chart for its method of showing the vertical profile of the approach. - Scanned from Air Disaster - Volume 3 - (Abbas Ali Collection)
The approach chart used by the Pakistani crew was particularly criticized for its method of showing the vertical profile of the approach. "The minimum altitude at some DME fixes was not directly associated with the fix," the Nepalese Commission's report declared. And Pakistan International Airlines' own report recommended that ICAO "should review the conventions of commercial approach charts with a view to encouraging standardization and reducing chart clutter".
Here's 'Flight International' magazine (July 7-13 1993 issue) report with excerpts from official report.
Left to Right: First Officer Hassan Akhtar, Capt. M. Nazeer 'Lala' and First Officer Farooq Ahmad. Hassan Akhtar was First Officer on PIA Airbus A300B-203 (AP-BCP) flight PK-268 that crashed minutes before landing at Kathmandu Airport, Nepal, September 28, 1992.
AP-BCP photographed by Guido at Rome-Fiumicino Airport, Italy, in March 1992, just few months before the aircraft met tragic accident in Nepal on September 28, 1992.
Umar Anis flew aboard AP-BCP on February 12, 1989 and visited cockpit. The photo shows AP-BCP registration seen applied on flight deck panel and below the registration mark is aircraft's SELCAL code FL-AC.
Flight PK-268 Memorial Park
The memorial built by PIA in memory of flight PK-268 crew members & passengers is named 'Lele Memorial Park'. It's built at the foot of hill where AP-BCP crashed.
Stone walls of this simple but beautiful memorial are engraved with names of all PIA crew members and passengers who died in this tragic crash.
Here are some video stills from PTV's Urdu drama serial "Uraan" about PIA. These are from serial's episode related to PK-268 tragedy.
Hilly area surrounding “Lele Memorial Park" dedicated to PK-268 crew members and passengers. Lele is name of a village near Kathmandu.
Plaque bearing park's name.
Close-up shot.
Another view of hilly area surrounding memorial park.
Steps leading to memorial's area where names of crash victims are engraved on stone walls and from where this shot was made. The small structure in the background at the start of steps is where plaque bearing memorial park's name is placed.
Stone walls of these arches are engraved with names of crash victims.
Names of PIA crew members. Iftikhar Janjua was aircraft's captain.
More names of PIA crew members. Names of aircraft's First Officer Hassan Akhtar and Flight Engineer Muhammad Ashraf also seen here.
Some more names of PIA crew members.
Beads
Post by Beads »
Gosh, it's so sad looking at those pictures. Especially the shoe, the watch and the bag.
captain_salman
Post by captain_salman »
Beads wrote:Gosh, it's so sad looking at those pictures. Especially the shoe, the watch and the bag.
and the name of the deceased is still existing on that brief-case! but the person is persihed! :cry: , people are gone and their belongings remain in this world! all they took with them selves is their deeds (Amaal). very very heartening! I am feeling so sad for the innocent passengers! May Allah rest their soul in Eternal Peace! Ameen! :cry: what more upseting is that the wrist-watch picture, there's torn human flesh around I think just beside the watch :cry: Allah hu Akbar!..............i had forgotten that tragedy long time ago but its all refreshed now :cry:
but what i do not understand is how cum the pilot did not came to know that he was descending at right glide-rate and did the A300 had the ground clearance warning system? :( it is understood that it was a very thick fog there on the mountain and with cloud aswell.....but if only they might have taken a little less descent-rate approach they could've crossed that mountain...... atleast the DME appears that way.... they should not have trusted the ATC radar..... this is what happens when there is miscommunication by the ATC to the plane! The ATC should have alerted the crew in advance that they were below their assigned altitude! but one thing here i'd like to point out is why did not the pilot used the altitude they were cleared for...why on earth they lowered their approach! :-s still that is just my thought....God know what those poor pilots might have done to save themselves... :(
after this crash the second most freightening crash to me is the Los Rodeos Airport (now Tenerif Airport) crash involving a KLM and PanAm both B747s ....again due to fog! gosh...
Probably that brief case belonged to Mr. Pervaiz Malik who's name appears in list of PIA Crew at memorial built near crash site.
PK777
Post by PK777 »
Very tragic indeed.. First time Ive seen this post. Thankyou guys for all the information and photos.
AP-BGL
Post by AP-BGL »
Really sad... Its even more throbbing when there had been no problem recorded in the plane and the journey ends in this way...
Adnan
