Help Needed On CLS A330-200
ahmedshaikhani
Post by ahmedshaikhani »
Assalam-u-Alaikum !
Hello Guys I need some help on CLS A330-200/300. I am facing problems while flying from VOR-VOR. I can't fly my plane on the autopilot on the navigation system. Where else I can easily do ILS landing and I can even fly on the Direct GPS. But I am facing problem VOR to VOR I can't navigate. Please help me out.
PIA - F27, ATR42, A310, B742, B743, B772, B773 | SA - A300, B743, B744, B772 | EK - A332, A345, B773 | Thai A300, A333, A346, B744, B772 | Malaysian B734, A332, B772 | Air Asia A320 | Fire Fly ATR72.
Re: Help Needed On CLS A330-200
ahmedshaikhani wrote:Assalam-u-Alaikum !
ahmedshaikhani, it does not matter that you fly Direct GPS, VOR-VOR, Low Altitude Airways or High Altitude Airways.
What you have to do is, once you are switching over to autopilot, switch the GPS/NAV mode to GPS mode and engage the NAV button on autopilot console along with Altitude hold, IAS hold with Auto Throttle engaged.
Then the system will follow the flight plan being loaded in GPS as per the FS flight planner and will follow the flight route till destination.
also note that when you will engage the NAV button on autopilot console, the Heading hold will be disengaged.
P.S. last evening i have bought the Logitech® Extreme 3D Pro and upgraded the RAM as well, currently having 1.5 GB RAM to test the FsX
ahmedshaikhani
Raihan Bhai I have tried this stuff. This process is not there in CLS A330 I have previously flown on VOR - VOR by this method. But this thing doesn't implements here.
ahmedshaikhani
Raihan Bhai thanks alot for your support know my problem is solved. The navigation switch was in the same switch where the heading lock was.
