Requesting the call signs for PIA
saadm80
Post by saadm80 »
I want the call sign for pia because when ever i fly i atc identifies from the tail number...
CPH-PAKiz
Post by CPH-PAKiz »
the callsign is "pakistani"
like flight from pakistan-norway-denmark it is flight number 771/772
Pakistani 771 or Pakistani 772 on ATC :wink:
Regards... Dani and Uss
<CENTER><SCRIPT></SCRIPT></CENTER>i
cpt_747
Post by cpt_747 »
I think he was asking "how to add call sign for his aircraft"
Open your Flight Sim folder:
"C:\Program Files\Microsoft Games\Flight Simulator 9\aircraft"
in the Aircraft folder you will see a file called Airlines (right at the bottom) open it (it's a read me file) and just add your desired call sign. Do you want to save it, Click YES.
Now Run FlightSim, select aircraft, now you will see the ATC Call Sign menu, click on it and in the "Change" and select your desire call sign that you saved in the Airlines folder.
Job Done! :wink:
Which means we're travelling 97 times the speed of sound. And yet we can't feel the motion,
SubhanAllah
saadm80
Post by saadm80 »
Guys i cant find it there is any other solution then please let me no.... thanks
Aer Pakistan
Post by Aer Pakistan »
call sign for pia is pakistan pluss flt number. eg Pakistan786, Pakistan302 .
Muhammad Ali - London - UK
Always Pakistan First, Pakistan Zindabad
