PIA ATR Flight PK-517 Runway Excursion at Panjgur Airport
Re: PIA ATR Flight PK-517 Runway Excursion at Panjgur Airport
https://propakistani.pk/2018/11/17/pia- ... intenance/
According to the link above, necessary maintenance and repair work has been completed on the aircraft but it still awaits clearance.
As usual the lobbying will protect the obvious culprits behind all this episode
Updated information on 'The Aviation Herald' with the inclusion of Pakistan's Safety Investigation Board (SIB) preliminary investigation/findings.
http://avherald.com/h?article=4c019bc5&opt=0
Nov 23 'update ' from CAA just says that plane overan rwy while landubg at Pangur and stopped so many feet after the rwy.
They just woke up, let them have tea and do usual morning chores. Then they will realize what the real work is to be done.TAILWIND wrote: Sat Nov 24, 2018 7:27 pmNov 23 'update ' from CAA just says that plane overan rwy while landubg at Pangur and stopped so many feet after the rwy.
Today, AP-BKY performed Karachi to Gwadar flight PK-503.
Source: radarbox24.com
https://www.flightradar24.com/data/aircraft/ap-bky
In the aftermath of the incident in Panjgur that occurred in November 2018 where an ATR skidded off the runway, using the hot and high approach and then making some elementary level mistakes. That prompted an inquiry into the pilot’s credentials which were found to be dubious. The same was reported to the regulator and PIA requested Government of Pakistan to constitute a high level inquiry into the matter which the Aviation Minister ordered immediately.
Source: PIA Press Release
One of flight PK517 pilots also had dubious/suspicious licence, according to news channels.
Aircraft captain also has suspected CAA exam results in the list issued by the Aviation Division, according to news sources.
Does anyone know names of the cockpit crew of this accident?
Cabin Crew did their job very professionally there was no panic
November 10, 2018, PIA ATR 72-500 (aircraft registration AP-BKY) flight PK517 from Karachi runway excursion incident at Panjgur Airport final investigation report by Aircraft Accident Investigation Board (AAIB) of Pakistan available here:
https://aviation.gov.pk/SiteImage/Misc/ ... 5B1%5D.pdf
Incident Cause/Contributing factors
Cause:
Involuntary Runway Excursion (RE).
Contributing Factors:
Disregard of landing limitations (overweight condition upon landing with one brake inoperative).
Disregard of operating procedures (high approach speed).
Inadequate decision making (indecisiveness of captain).
