Livery
Can anyone of you design the following livery?
Take the current PIA livery and change the tail to Pashmina design with bold white PIA written in the center. Then don't stop the Pashmina design on the tail but instead let it go on the fuselage until you reach the dark green stripe. So basically, the back-half of the fuselage should have green Pashmina design with off-white background. The front-half of the fuselage should remain the same except change the PIA letters to Pakistan in dark green colours and the urdu script to dark green as well. Also, the engines should have off-white background with Pashmina design on top of it.
I was just wondering how it would look. It would be great if someone could do that. Thanks.
that would look good but a bit too much for PIA and the re-painting would cost quite a bit.Ali Hasan wrote:Can anyone of you design the following livery?
