PIA ATR Emergency Landing at Islamabad Airport
Acc to news report today an Atr made an emergency landing after 1 engine failure due to bird strike
Reason: Topic title edited.
Re: PIA ATR Emergency Landing at Islamabad Airport
According to reports on news channels, on November 23 a PIA ATR performing flight PK632 from Sukkur Airport landed safely at Islamabad Airport after suffering bird/foreign object hit. Cockpit crew received engine number 2 fire warning after bird/foreign object hit. The affected engine was shut down and "Mayday" call was sent by the cockpit crew to air traffic control about 2 nautical miles away from Islamabad Airport. The emergency services were alerted at Islamabad Airport for aircraft landing. The aircraft has been grounded for inspections/repairs.
PIA ATR 42-500 registration AP-BHI at Islamabad Airport.
On November 23, PIA ATR 42-500 registration AP-BHI as flight PK632 from Sukkur landed safely on Runway 28L of Islamabad Airport at 10:41 PM.
Islamabad International Airport Primary Runway 10R/28L and Secondary Runway 10L/28R.
Apparently, AP-BHI has not returned to the skies after landing at Islamabad Airport as flight PK632 from Sukkur on November 23.
November 24, PIA Islamabad to Gilgit flight PK601 has been cancelled for some reason. The flight was scheduled to leave Islamabad at 6:50 AM and apparently ATR 42-500 registration AP-BHI was expected to perform this flight. PIA flights to Gilgit are also subject to weather conditions.
https://www.flightradar24.com/data/aircraft/ap-bhi
Media reports are inaccurate regarding the bird strike immediately before the fire indication warning. The bird strike occured some time before and the aircraft was declared airworthy.
Make the 100% correct decision 100% of the time.
Today, PIA ATR 42-500 registration AP-BHI departed from Islamabad Airport Runway 10R at 7:09 AM as flight PK601 to Gilgit. For some reason, the aircraft landed on Islamabad Airport Runway 10R at 7:30 AM. Maximum altitude gained by the aircraft 4,925 feet. Flights to airports like Gilgit and Skardu sometimes return to Islamabad due to sudden changes in weather conditions on planned flight path or at destination airport.
Later, PIA ATR 42-500 registration AP-BHI departed from Islamabad Airport Runway 28L at 9:03 AM as flight PK601 to Gilgit.
First flight was a check flight
^ Thank you for the info.
Jang news report: https://e.jang.com.pk/detail/298832
According Urdu daily Dunya November 25 news report, PIA and Pakistan CAA officials reviewed PIA ATR 42-500 registration AP-BHI engines' maintenance record and found it satisfactory. The aircraft had received engine fire warning before landing at Islamabad Airport as flight PK632 from Sukkur on November 23. The aircraft's both engines also underwent extensive inspection and were found in condition meeting safety standard. The aircraft also underwent ground test on November 24 at Islamabad Airport.
Maybe this video grab shows ground testing of PIA ATR 42-500 registration AP-BHI at Islamabad Airport on November 24 after engines' inspection?
Express News
Express News
Yes it happened at SKZ on arrivalMikeTangoKiloAlpha wrote: ↑Fri Nov 25, 2022 2:09 pm Media reports are inaccurate regarding the bird strike immediately before the fire indication warning. The bird strike occured some time before and the aircraft was declared airworthy.
