Saudi incident at ISB - big deal?
Close call for Saudi Airways flight
By Our Staff Reporter
RAWALPINDI, Aug 15: A Saudi Airways Boeing 747 with 353 passengers on board narrowly escaped a disaster when six of its tyres "deflated" while landing at Islamabad airport on Saturday, sources said.
A senior official of Saudi Airways, when contacted, said six tyres of the flight SV-3722 deflated when brakes were applied.
"Usually, deflating of tyres happens due to overheating of wheel drums. However, the landing was smooth and nobody was hurt," the official said.
He added that spare tyres were brought from Saudi Arabia through another flight on Sunday. The aircraft took off for its destination after tyres were replaced.
Source: DAWN
Source: DAWN
What I meant was that incidents in Pakistani airspace have become very frequent. For example, near miss collisions (2 - 3 near miss during the last two months), now tires bursting, whats next ?AP-BGL wrote:Do you think the tyres which get deflated were due to Pakistani airport?basit_s wrote:Pakistani airspace and airports are becomming dangerous with time.
az inja boro. nemikham bebinamet dige toro.
Isn't the length of this runway 30L about 9000 ft.Moin wrote:Actually ISB airport runway is not very long. And upon touchdown, the thrust reversers and brakes have to be applied immediately, and if you note when the a/c makes a U turn to head towards the parking ramp area, you can actually see the end of the runway.
I could be wrong but I thought I read it somewhere.
All aircraft tyres have fuseible plugs that deflate them beyond a certain heat generation threshold in order to pre-empt bursting of the tyres. That is an inbuilt manufacturing feature.
Stopping distance of any jet is calculated based on brakes and spoilers only, Reverse Thrust credit is not taken into account on dry airfields.
ISB has adequate runway length. The only factor to be considered is when its raining there since that tends to create aquaplanning or hydroplanning due large rubber deposits in the touch down area making it very slippery whilst landing.
Rest its a fairly regular airfield.
ISB airport runway isn't short...9000 ft??Adnan Anwar wrote:Isn't the length of this runway 30L about 9000 ft.Moin wrote:Actually ISB airport runway is not very long. And upon touchdown, the thrust reversers and brakes have to be applied immediately, and if you note when the a/c makes a U turn to head towards the parking ramp area, you can actually see the end of the runway.
Runway 30 is 10,800 feet...London Gatwick is even shorter.
You're right ISB runway length is adequate, however a number of other factors are to be considered such as the elevation, runway surface, and climatic conditions.
For example on a hot day, high elevation, and a wet surface condition would present a bit of skill test to put an let's say 170 tons of metals doing aound 150 mph, the inertia involved is tremendous. However like i stated earlier ISB is a fairly regular airfield.
