We should not be accusing or defending people here...... but still the acft over ran the runway and got substantially damaged, as per ppl in ATC, it was high, landed long, so something went wrong during approach and landing...... isn't it ?A310 wrote: ↑Sun Jul 21, 2019 2:12 pm [SM post_id=192872 time=1563693084 user_id=278]
Your revised math sounds completely flawed as well. No sane pilot would make an approach at even 150 on an ATR and that too at one of the most difficult approaches in Pakistan. But again your expertise is based on a poor quality video made by a passenger. That shows you’re an integral part of the SIB. On another note, I’d love to tell you that an ATR requires only 2800 ft out of the total 5000 ft of the runway at Gilgit. While touching down at the threshold sounds safe, even if the pilots touch down after passing 2000ft the landing would be a safe one. But please continue with your criticism of one of the best commanders on PIA ATRs.
PIA ATR Incident at Gilgit Airport
Re: PIA ATR Incident at Gilgit Airport
You’re right. I’m not saying that the pilots should be let free. They’re already grounded and an inquiry will be held. And if they’re found guilty then they should face consequences. But I am trying to refute the allegations made by a member of forum. Neither does he know nor do I know about what actually happened. You guys should know that it isn’t possible to perform a go around at Gilgit airport. I might agree with you that the aircraft landed way past the runway threshold but none of us can interpret the speed of the aircraft. It is wrong to make assumptions. Some members are so keen on blaming the Captain that no one has shed a light on the sooo efficient Engineering department PIA has. I’m not blaming them but there’s a possibility, no? Similarly anything could’ve gone wrong with the brakes but alas we just want to dismiss the pilots.TAILWIND wrote: ↑Mon Jul 22, 2019 3:19 amWe should not be accusing or defending people here...... but still the acft over ran the runway and got substantially damaged, as per ppl in ATC, it was high, landed long, so something went wrong during approach and landing...... isn't it ?A310 wrote: ↑Sun Jul 21, 2019 2:12 pm [SM post_id=192872 time=1563693084 user_id=278]
Its the pilots fault anyway! Way to go guys...
I agree with most of your thoughts; however, just as a little correction: there is a go-around procedure at Gilgit that PIA pilots have within their publications. Also, unlike Chitral, Gilgit's runway can also be approached from both ends.A310 wrote: ↑Mon Jul 22, 2019 6:32 amYou’re right. I’m not saying that the pilots should be let free. They’re already grounded and an inquiry will be held. And if they’re found guilty then they should face consequences. But I am trying to refute the allegations made by a member of forum. Neither does he know nor do I know about what actually happened. You guys should know that it isn’t possible to perform a go around at Gilgit airport. I might agree with you that the aircraft landed way past the runway threshold but none of us can interpret the speed of the aircraft. It is wrong to make assumptions. Some members are so keen on blaming the Captain that no one has shed a light on the sooo efficient Engineering department PIA has. I’m not blaming them but there’s a possibility, no? Similarly anything could’ve gone wrong with the brakes but alas we just want to dismiss the pilots.TAILWIND wrote: ↑Mon Jul 22, 2019 3:19 amWe should not be accusing or defending people here...... but still the acft over ran the runway and got substantially damaged, as per ppl in ATC, it was high, landed long, so something went wrong during approach and landing...... isn't it ?A310 wrote: ↑Sun Jul 21, 2019 2:12 pm [SM post_id=192872 time=1563693084 user_id=278]
Can we have the official approach procedure for OPGT Rwy25?
There are no Jeppesen charts for OPGT but PIA has its own company charts for most northern area airports including Gilgit. I will try to see if I can get my hands on them.
Satellite-based navigation and Instrument Landing System (ILS) are available to develop Skardu, Gilgit and Chitral airports for all-weather, day-and-night operations. This can be done at a fraction of the cost incurred on the installation of the conventional ILS at the Lahore airport.
A recent development in satellite-based technology has made it possible for automatic systems on aircraft to navigate through the most difficult terrain, such as valleys, and approach to land through clouds and at night. One such example is Queenstown Airport in New Zealand. The same systems can be installed at Skardu, Gilgit and Chitral.
Required Navigation Performance (RNP) approaches with RNP values currently down to 0.1 allow aircraft to follow precise three-dimensional curved flight paths through congested airspace or difficult terrain. The RNP value of 0.1 means aircraft computer systems will keep the plane along its 3D curved flight path.
The system ensures that the aircraft remains within defined containment area. Think of it like a virtual highway in the sky. The aircraft is controlled both laterally and vertically. Its position is constantly updated through the use of multiple satellites. The system is equally effective during day and night, and in clear and cloudy conditions.
Other requirements include customised crew selection and training package, employing the full capability of the existing RNP technology, and changes to on-board flight procedures to reduce pilot workload on final approach.
General and business aviation aircraft equipped with Enhanced Low Visibility Operations (ELVO), such as Synthetic Vision System (SVS), Combined Vision System (CVS) and Head Up Display (HUD), will also be able to operate to these airports in marginal weather. In the United States, under the NextGen programme, a lot of progress has been made on this count.
A recent development in satellite-based technology has made it possible for automatic systems on aircraft to navigate through the most difficult terrain, like valleys, even at night
The design of missed approach path has been a major challenge in the past because of high ground (mountain) in the takeoff or missed approach path. Therefore, it has been preventing the installation of conventional ILS at these airports. This should be no more a challenge considering the recently acquired ability of the aircraft to follow the accurate 3D curved path in cloudy conditions.
Just a few weeks ago, President Arif Alvi told a press conference that tourism to the northern areas of Pakistan surged by almost 100 times between 2015 and 2018. Only 20,000 to 25,000 tourists visited these valleys in 2015. This makes the latest number of tourists close to 2.5 million each year.
At present, PIA operates two daily flights each to Gilgit and Chitral by ATR aircraft, and one daily flight to Skardu by A-320. ATR-42 is a 40-seater aircraft whereas ATR-72 is a 70-seater aircraft. Even these flights get cancelled when the valleys are blocked because of clouds. The passengers/tourists who get stranded at departure or destination because of weather often create havoc. The road infrastructure is so long, inconvenient and dangerous that it deters them from seeking any other mode of conveyance.
The current government intends to encourage tourism in the northern areas. It should direct the Civil Aviation Authority (CAA) to develop these three airports on the lines of Queenstown Airport in New Zealand. To do this, the CAA will have to seek international consultancy as local expertise for RNP-AR does not exist at present.
The development of airport and air navigation infrastructure is one of the primary objectives of the CAA as per the 1982 Civil Aviation Ordinance and National Aviation Policy. To do so, the CAA is already charging fees from airlines and passengers in line with provisions of the International Civil Aviation Organisation (ICAO).
Airport and air navigation services are called natural monopolies. Therefore, unlike airlines, the CAA doesn’t compete with others. It is, therefore, in a position to increase charges or fees to plug in the gap between revenue and expenditure.
The CAA pays corporate taxes of over Rs15 billion every year, which is about 30 per cent of its operating profit. This means the CAA earns far more than it spends, resulting in such a heavy tax liability every year. Sufficient funds are, therefore, available for the development of a satellite-based, all-weather landing system in Gilgit, Skardu and Chitral. The installation of such a system costs only a fraction of the conventional ILS system. All three airports can be equipped with satellite-based ILS at the cost of one conventional ILS installed at the Lahore airport for Rs3bn. It will include the cost of Ground-Based Augmentation Systems (GBAS) and approach/runway lighting system etc at all three airports.
Gilgit and Chitral airports, with their limited runway length of about 5,000 feet each, are fit for turboprop aircraft operations only, such as ATR-42/72 etc. The Skardu airport, with its 12,000-foot runway length, is fit for operations of jet aircraft up to Airbus 320.
Once installed, our domestic airlines will be required to invest in crew training and upgrade of on-board equipment. Should domestic airlines not be interested in such a venture, these airports may be opened to foreign airlines by expanding existing air services agreements either bilaterally or unilaterally.
Uninterrupted and unfettered airline operations to the northern areas will not only enhance domestic tourism but also revolutionise the local economy.
The writer is an air navigation services expert
Published in Dawn, The Business and Finance Weekly, February 4th, 2019
Resembling the official approach procedure published by PIA
https://www.theairlinepilots.com/foruma ... it-ops.pdf
Let's shoot across the sky..
https://youtube.com/iTechno8
Pakistan Army troops arranging to move the aircraft. Maybe it can be repaired at Gilgit too?
Thanks a lot for sharing, Shuja. This is very helpful.iTechno8 wrote: ↑Mon Jul 22, 2019 4:35 pmResembling the official approach procedure published by PIA
From these photos, the flap setting seems insufficient for landing at a relatively short strip. But again, at times, pilots do clean the flaps right after touch down to improve manual braking traction. Hopefully, the CVR and FDR will tell what the correct flap setting was at the time of touchdown.
I doubt author of this article has visited/seen gilgit, chitral and skardu airports to compare these with queensland airport.inducedrag wrote: ↑Mon Jul 22, 2019 10:32 amSatellite-based navigation and Instrument Landing System (ILS) are available to develop Skardu, Gilgit and Chitral airports for all-weather, day-and-night operations. This can be done at a fraction of the cost incurred on the installation of the conventional ILS at the Lahore airport.
Every aircraft has a Structural Repair Manual (SRM), which gives in detail the permissible repair procedure for damages depending upon:Charliedelta11 wrote: ↑Sun Jul 21, 2019 8:13 pm ........ what exactly will happen to ascertain structural integrity and so on. Asking out of curiosity.
1 - the type of damage i.e crack, puncture, fracture, dis bonding, breakage etc
2 - Extent of damage i.e how big, deep, wide is teh damage.
and most importantly
3 Location of the damage.
Normal damages are assessed as per criteria is given in the SRM, and if within SRM limits, there would be a corresponding generic or specific repair procedure and it can be carried out by the operator. However if the damage is out of the SRM limits, it is mapped and sent to manufacturer who then carries out a detail analysis and if found technically repairable, sends a detailed repair scheme.
Hope this helps
The damaged PIA ATR 42-500 (AP-BHP) has been moved to paved surface at Gilgit Airport and will be ferried to Islamabad apparently after temporary repairs at Gilgit.
Initial investigation reveals late touch down with high speed as the cause of PIA ATR 42-500 (AP-BHP) accident at Gilgit Airport, said Aviation Minister Ghulam Sarwar Khan in programme 'Khara Such' hosted by Mubasher Lucman on 24 news channel.
On a clear day with good visibility, dry runway, an aircraft overshooting a runway can only be a serious piloting error. There is no 2nd opinion, unless you are friends with the pilots.
