I have a slack attack 3 joystick that I used for FS but i can't really turn on the ground when I'm taxiing. This joystick only helps me pitch and bank, but there's no yawing.
Does anyone know if there are FS joysticks that include a nose wheel gear on the side or help me yaw in the air or turn on the ground? What is the best recommended joystick for FSX? Thanks
Best FS joystick for taxi/yawing?
Re: Best FS joystick for taxi/yawing?
I use Logitech Extreme 3d Pro and it can fulfill your requirement
https://www.google.com.kw/search?q=logi ... e&ie=UTF-8
I am using Cyborg Gold 3D USB and it yaws by twisting the handle about its axis. Works very fine for taxiing if you set the "fire" button to act as brake button
Ian using the Saitek Cyborg FLY5 Joystick - its great Joystick for FS Flying and its not too expensive.
http://www.saitek.com/uk/prod/fly5.html
Best Regards / Wa´alaikumusalam
Any idea where i could get the Logitech 3D Pro or the Saitek Cyborg in Lahore?
