Faisalabad Airport to be Upgraded
Re: Faisalabad Airport to be Upgraded
Faisalabad Airport primary Runway 03R/21L upgrade project work to continue at least till May 17, 2023. Heavy machinery deployed on Runway 03R/21L.
Airport's secondary Runway 03L/21R to remain available for flight operations.
Faisalabad Airport runways:
Primary Runway 03R/21L
Secondary Runway 03L/21R
Post by Amaad Lone »
you can upgrade all the airports you want, its the population that needs to be upgraded through education.
The people visiting these airports are mostly illiterate and destroy the atmosphere and the joy of landing in your home country.
The security agencies wake up after the airport is made and destroy it in the name of security by blocking off lanes and creating bottle necks and obviously lets not forget VIP LANE 1 AND VIP LANE 2.
From May 18 to May 30.
Faisalabad Airport main Runway 03R/21L will remain closed for aircraft operations due to runway reconstruction work. Aircraft operations will continue from secondary Runway 03L/21R. Heavy machinery is deployed on main Runway 03R/21L. Pilots advised to exercise caution while landing/takeoff from secondary Runway 03L/21R.
Faisalabad International Airport has been certified for aircraft operations up to aerodrome reference code 4D or below for the time period from May 29, 2023, May 29, 2026 with following conditions:
A) Width of the runway strip Runway 21L will be 105 meters on the eastern side (right side of Runway 21L).
B) Aircraft operations shall be undertaken compatible to equivalent surface strength published for apron to be used.
Aerodrome with 4D reference code allows operation of passenger/cargo aircraft up to category of Boeing 767/McDonnell Douglas MD-11
On May 31, 2023, reconstructed main Runway 03R/21L of Faisalabad International Airport was made available for flight operations.
PIA Airbus A320 aircraft registration AP-BMY flight PK224 from Dubai landed on reconstructed main Runway 03R/21L of Faisalabad International Airport at 10:00 PM on May 31.
The reconstructed main Runway 03R/21L of Faisalabad International Airport is capable of handling Boeing 777 category wide-body aircraft.
