Very Much Edited:
Less edited shots;
Comments and suggestions are welcomed!
That's an awareness message for young guys who think spray paints are cool if used politically!btw Altaf hamara Qaid aint written on any of the buildings around
Are spotlights for intruders?and btw, I hope you can add this: All around the airport fence, white spotlights have been installed. They're like the ones that came in RWY12 Object Placer, hope you get the idea...
Any pictures of the houses?now, towards the far end of RWY 36R, a dozen or so new houses have been built and come very, very close to the airport perimeter fence.............
System specs? I already have a detailed grass polygon layer added to the ground, so even if you aren't using the 3d grass, you'll see it alright.in case this proves to be a performance eater, will it be possible to have a 'light' version for the ghareeb awam like me? perhaps ground like the one you did at KHI?
msarmadk wrote:btw Altaf hamara Qaid aint written on any of the buildings around
Actually no, they're for the security guards.Are spotlights for intruders?
Affirm. This is what they look like at a 90 angle to the RWY. (far end of 36R)Any pictures of the houses?
Inspiron 1525/Dual core 1.7GHz/3GB RamSystem specs? I already have a detailed grass polygon layer added to the ground, so even if you aren't using the 3d grass, you'll see it alright.
Just wow!
