Freeware Gilgit FS2004: Progress
msarmadk
Post by msarmadk »
Help and pictures needed! :wink:
msarmadk
Re: Freeware Gilgit FS2004: Progress
Post by msarmadk »
Hey guys, I am looking for terminal area photos for Gilgit airport, it would be appreciated if you can find photos other than the one's on flickr.com
Thank you.
irfan khan
Post by irfan khan »
Maybe this will help you.............
Pics Deleted
Regards
Thanks and Best Regards
http://www.vpia.org
msarmadk
Post by msarmadk »
Thanks a lot but I was expecting pictures of the terminal or the airport building if there is any!?
sarmad, good luck with your Gilgit project :thumbs_up:
msarmadk
Post by msarmadk »
OK, i am down to doing this airport but we probably should have someone doing the surrounding since it's so beautiful! :D
msarmadk
Post by msarmadk »
A test flight with a scratch start! :)
Comments most welcomed!
irfan khan
:D good shots MSK really a good start for gilgit but i want to ask you something are you going to do the surroundings also the play ground near the airport and greenery?
http://www.vpia.org
msarmadk
Post by msarmadk »
No plans YET! :wink:
msarmadk
Post by msarmadk »
some more shots!
excellent details of textures, thanks for sharing...
msarmadk
Post by msarmadk »
At last found a way to do better edges for ground polygons!
msarmadk
Post by msarmadk »
Latest updates for today!
excellent work, is it the same method of Loft (get shape)? then in such case, i think the edges will be more close to reality as the texture quality will be....
overall, great job including the taxiway line and other ground texutring....looking forward for more screenshots :thumbs_up:
sarmad, why not using PIA's ATR42 or at least F27 in the screenshots of GIL?
msarmadk
Post by msarmadk »
I don't have a model of the ATR or the F-27 in my collection!
And yes I did use the loft method while keeping the direction of the drawn lines in consideration as well otherwise I would've had wrong sided edges for the polygons! :wink:
