autopilot on Beechking air for FS2004
Anyone know where the altitude hold and heading hold are located on the king air for flight simulator 2004?
I plan on doing some flights to muzzaferabad airport in those but cant operate the whole flght manually. I know i gotta land it myself as I dont believe that airport is equipped with ILS.
But any help on the autopilot for beech king air would be appriciated
buddy, will check that out for you
lol...i have fs98 onwards all versions of FS
check if the panel is same? and i have mentioned some major controls for AP. Have any further question?
happy flying
happy flying
o dear, in the Autopilot Console, note following:Nadir Ali wrote:yeah i have one more qyestion, where is the heading hold switch?
AP - Autopilot Master Switch
FD - Flight Director
HDG - Heading Hold
ALT - Altitude Hold
NAV - Navigation Hold
B/C - Backcourse Hold
APPR - Approach Hold
Y/D - Yaw Damper
i hope this will be clear for you
yes it is... the scenery is available on AVSIm or Flightsim, but i dun recall the airport, its somewhere up north, either skardu, gilgit oro something!captain_salman wrote:Is that truck up ahead is a Pakistani truck? you know the ones decorated? if yes I want that truck!!!
REGARDS--
Mohsin Naseem - PIA10141
Mohsin & captain, it is a GIL/OPGT as you can read the ATC window details showing the frequencies for Ground/Tower.PIA10141 wrote:yes it is... the scenery is available on AVSIm or Flightsim, but i dun recall the airport, its somewhere up north, either skardu, gilgit oro something!captain_salman wrote:Is that truck up ahead is a Pakistani truck? you know the ones decorated? if yes I want that truck!!!
^ captain, that truck is static model used by scenery designer. it will not be available separately but you have to download the complete scenery. search for gilgit on flightsim.com and the scenery is not available seperate but bundled with northern areas including some scenery for occupied kashmir as well.
