Allama Iqbal International Airport In progress
msarmadk
Re: Allama Iqbal International Airport In progress
Post by msarmadk »
Then you don't have the right path to the folder.
Extract it to a temporary folder and then re-add the area to your FS scenery library.
Delete the old area.
Abdullah Saleem
Post by Abdullah Saleem »
By deleting the old area. What do you mean? Deleting from FS Library or deleting folder Lahore Airport Scenery
"GOD KIND TO THOSE WHO KIND TO OTHERS"
Cricpak (Administrator)
msarmadk
Post by msarmadk »
Both!
but when you get this msg
SCENERY.CFG file error. Invalid Remote scenery path in scenery Area.039. Click OK to Continue
Then that means your folder is not correctly added to the library.
Abdullah Saleem
same error, still.
It's showing nothing in Name box.
msarmadk
Post by msarmadk »
same error, still.
Check if the scenery folder is empty or not, because that happens when you give the wrong path to the simulator. I had it a few days ago, I don't exactly remember what I did to get that.
But also try putting all the "*.bgl" extension files in a sub folder name "scenery" and all the "*.bmp" extension files in a sub folder named "texture" of a temporary folder which will be the main folder and the one you will select from the scenery library.
I hope you understood what I said there! haha
