OPST - Sialkot Intl. Airport for FS2004 - Beta Release
Thank you all for your support!
I have work the whole thursday night and textured the ground totally....
but problem is when i use the TOP DOWN VIEW, the textures looks fine as you can see in the BACKTRACK preview shot and when i see the textures while being in the COCKPIT view, the textures get blurry
The textures which are applied as ground textures are in DXT3 format. Either, my graphics settings are not properly set or some thing else is wrong....
Here, i would like to mention that i have to re-do the paint job of ground textures as I am not satisfied with that at all! And the main thing is AFCAD rwy, for which i am unable to understand that why its not appearing on the top layer, already its on top layer in Scenery Library....so dont consider that particular rwy texturing will be released as the AFCAD rwy has to take over the job for happy landings.....
cockpit view, seconds before touchdown.....
backtrack using rwy22.....
raihan bhai, i think it has nothing to do with your painting. remember, when ali mujtaba released his first OPKC scenery. the textured runways were blurry too.raihans wrote:Thank you all for your support!
problem is when i use the TOP DOWN VIEW, the textures looks fine as you can see in the BACKTRACK preview shot and when i see the textures while being in the COCKPIT view, the textures get blurry![]()
by setting the mipmaps in fs display settings makes the runway textures and other textures sharp, i think.
you're doing a great job
arifm, thanks for the suggestion....already i am using the max possible options of my graphics card, here are the setting details:
the problem is not the settings but the picture itself that you are using for ground textures. You need to create a layer with semi-transparent noise and lay it on top of the ground so it looks a bit sharp or
put the noise textures underneath the scenery and then use alpha channe l on the apron, runways and taxiways to make it look sharp.
examples can be seen in your "fs9/textures" folder. lookup any file named *_detail.bmp
tell me if this helps.
Sarmad
Sarmad
^ thank you msarmadk for the details, i will check and will notify with any progress....
arfim, some temporary halt on the project as working on VASIM - flight schedules.
Today onwards, Insha'Allah resuming the work as yesterday our building electricity has been resumed by the ministry after winning the case logged in court due to dispute with our Kuwaiti building owner
...eh a 3 week mental stress with no electricity in this hot temp around 50c
Ohhhhh...how can you live in this temperature without electricity...poohraihans wrote:Today onwards, Insha'Allah resuming the work as yesterday our building electricity has been resumed by the ministry after winning the case logged in court due to dispute with our Kuwaiti building owner...eh a 3 week mental stress with no electricity in this hot temp around 50c
Best Regards / Wa´alaikumusalam
Sialkot Release
When will tha Sialkot international airport be relased, can someone please tell me?
