AirBlue to Get Windrose Airbus A330 on Wet Lease
Re: AirBlue to Get Windrose Airbus A330 on Wet Lease
Somebody told that Airblue Want to refuse from WINDROSE in MAY 2015 is it true ? Did they find some other operator?
Windrose Airbus A330-223 registration UR-WRQ departed from Karachi at 4:47 PM today as airblue ferry flight PA-1 probably to get positioned at Lahore Airport for its first commercial flight for airblue.
http://www.flightradar24.com/data/airplanes/ur-wrq
UR-WRQ landed at Lahore Airport at 6:16 PM. So, it means the A330 will perform its first revenue flight for airblue from Lahore.
Probably airblue flight PA-470 from Lahore to Jeddah on February 14?
UR-WRQ first revenue flight for airblue was flight PA-407 from Lahore to Karachi performed today. The A330 departed from Lahore at 6:29 PM.
UR-WRQ now performing airblue Karachi to Lahore flight PA-408.
UR-WRQ now performing airblue Lahore to Jeddah flight PA-470.
The return flight from Jeddah is delayed significantly. As of this post it has not departed when in fact it should have done so some 6 hours ago.
UR-WRQ landed at Lahore at 5:54 AM on February 16 as airblue flight PA-471 from Jeddah with a delay of one hour and twenty-four minutes.
UR-WRQ performing airblue Lahore to Jeddah flight PA-470 today also.
Today also UR-WRQ performed airblue flight PA-470 from Lahore to Jeddah.
So, since February 15, the A330 is performing airblue Lahore to Jeddah flight PA-470 and Jeddah to Lahore flight PA-471.
http://www.flightradar24.com/data/airplanes/ur-wrq/
After taking rest at Lahore Airport on February 18, UR-WRQ today again performing Lahore to Jeddah flight PA-470.
They seem to be under utilising the aircraft!
Why aren't they using the A330 for flights to Jeddah from Karachi and Islamabad?
They can position the aircraft for Jeddah flights from Karachi and Islamabad by operating the aircraft on domestic flights between Karachi & Lahore and between Karachi & Islamabad.
Like for example:
Lahore->Jeddah->Karachi->Jeddah->Lahore.
Lahore->Karachi->Islamabad->Jeddah->Islamabad->Karachi->Lahore.
I think they will also need maybe one more A330 for operating wide-body aircraft Jeddah flights from Karachi, Lahore and Islamabad.
Like for example:
Windrose Airbus A330-223 registration UR-WRQ wet leased to airblue seen at Allama Iqbal International Air Port (AIIAP) - Lahore.
airblue is using the A330 for flights between Lahore and Jeddah.
Windrose Airbus A330-223 registration UR-WRQ soaring through overcast sky of Lahore as airblue flight PA-470 to Jeddah today.
